Any downside to running 6-700 RPM idle?
sebsi
My tercel:: 1984 SR5 4wd
Post by sebsi »
I was a bit amazed that I could set the idle on my '84 this low. It vibrates a bit but seems to run very smooth. Is there any reason to set it otherwise?
Blake
Re: Any downside to running 6-700 RPM idle?
yes, it could stall out if you stomp on it too fast, or try taking off from a stop with sloppy clutching. Could die off when idling when really hot out. But no harm done. I would not set it below factory.
