Differences between early and later T4wd?
Do any of you know all of the differences between the '83-'84 early Tercel 4wd, and the '85-'87 later models.
Here is what I can remember:
early SR5: has inclinomoter on dash, 3.73:1 diff ratio, early style steel wheels, plaid style uplstry fabric, some early '83 also have "4x4" decals on the front fenders and large "Toyota" decal on the rear hatch.
Later SR5: 4.1:1 differentials and closer spacing on the first 3 trans gears, different upholstery patterns and colors, slightly larger outside rear view mirror, different steel wheel designs. The '87 has different element type headlights.
There are also two types of alternators (one with an internal regulator and one without), and some also have apparently a gear reduction starter, but I do not know if that by year, or just a random production option.
Does any one know of any other differences?
Re: Differences between early and later T4wd?
My early '83 (built 10/82) did not have the 4x4 decals you mention; perhaps that was a dealer option?
The '86 has the center rear brake light and vertical parking position for the rear wiper, and of course a slightly different parcel cover.
That's all I can recall...
EDIT
EDIT
Thanks for confirming it! I thought I was misremembering the aerial being on the left on my '83, as in retrospect it seemed like an inefficient way to route the aerial lead (the Toy beancounters missed on this extra cable length!).buffalomesa wrote:83 and 84 have the antenna on the left fender, and the 85-up have it on the right fender.
- My tercel:: 1986 Dlx 2WD Wagon
83 and 84 have the antenna on the left fender, and the 85-up have it on the right fender. Some 83 base wagons have lowback bucket seats with a small headrest.
funny you should note the antenna location, in the local Pull-a-part in Arlingtion WA they have an '84 and an '85 side by side and I noticed the antenna locations yesterday, but it did not occur to me to note that.
I also have a "spare" right side fender I never used on my '83 (now junked as a parts car), and it has an antenna in it. And it is even the same color as my current '84, with an antenna on the left fender. Should I ever need it, is there some reason I should have two antennas? Or should I just plug the hole?
Or perhaps since I am putting the 4.1:1 final drive and tranny from an '85 into my '84, I can put the fender on it and I would eventually have a '84-'85 Tercel? Come to think about it, the engine in it came from an '83. So do I have an '83-'84-'85 Tercel? Perhaps I should write an econo version of the Johnny Cash song about the guy who worked in the Cadillac factory.
I want eventually to build up a Tercel with all the best parts from all the years, and even from other models of Toyotas, such as the engine and brakes.
When I was in HS (late '50s), the hot thing if you had a post '53 Ford, Plymouth, or Chevy was to have two antennas; one on the top of each rear fender, even if only one was connected.Petros wrote: Should I ever need it, is there some reason I should have two antennas?
And curb feelers were de rigueur, too!
What can I say?
- Neu
that you're old.ARCHINSTL wrote: What can I say?
ohh boy I call this fun !
(1) rear hatch door and front grill that say "tercel " number 4 and letter WD are different 83-84 same, 85-88 same
4WD
(2) " cluster" 85-86 "EL" light goes on when use EL in gear , 83-84 no light showed but 87-88 ? will check it out later
(3)ANTENNA I seen many right or left side on same year car BUT 86 I have pull up and down antenna and also on 1987 too.
(4) rear wiper arm 83-84 flat down ( HOZ..) for 85-88 wiper arm straight up (VERICAL)
(5) big square plastic thing mount at rear hatch door where the licence plate screw on 83-86 same ,87-88 change style
plus add chrome on the edge.
(6) 87-88 they paint black on all doors frame , earlier model ?
(7) here a tricky part 83 maybe 84 both side veiw mirror on front doors, there NO rubber cover over ther door frame ,
85 -88 have bigger rubber mount on mirror which cover half of the door frame .
(8) 83-84 steering wheel which i have , have not seen in this forum so far will take picture later
4WD
I can remember the curb feelers...which were just spring wire "feelers" that extended out past the tires...supposed to make a sound so you'd avoid scuffing those whitewalls. Fuzzy dice. Hula dancers on the dash.ARCHINSTL wrote:When I was in HS (late '50s), the hot thing if you had a post '53 Ford, Plymouth, or Chevy was to have two antennas; one on the top of each rear fender, even if only one was connected.Petros wrote: Should I ever need it, is there some reason I should have two antennas?
What can I say?
Redline tires were the ones for the serious racers....they didn't like the Michelins (early radials)...they would stick real well...till they suddenly let go.
Early sixties...not so old...but old enough to know better than Neu?
Both my '83 and '84 had black door frames. The '83 it was almost all faded off, I repainted my '84 to make it look clean.toughtercel wrote:ohh boy I call this fun ! .....
I have noticed the mirror changed, they are slightly bigger too, and more "stream lined" (as if that is going to help the drag on a little box), but I like the style more and I am thinking of switching to later style.
I think the steering wheels are all same, the later ones are only a different color (black). Except perhaps the last year, the spokes were at 7 o'clock and 3 o'clock like on the corolla if I recall.
No curb feelers for me thank you. The earliest memory of our family car, a '57 Oldsmobile I think, had these devices. I remember playing with them when I was a toddler when the car was parked in the driveway. Odd what sticks in your mind from those early years. I think they are more cosmetic than practical, but they sure were popular.
Boy - between you and Neu...Petros wrote: No curb feelers for me thank you... I remember playing with them when I was a toddler...
I do have to tell you that my portrait, secreted in the attic, keeps getting grey and wrinkled, whereas moi...
as "petros"made a good discribe as ARMY code , steering wheel spoke located 7 o'clock and 5 o'clock wide flat , hand on steering wheel is bit soft and thick , and in the center have plastic logo snap-on ,picture of logo "EAGLE" hope one day if can get some picture in the upload attachment ,still having trouble .
ohh , what is exact date of the month of 1984 when diff ratio switch from 3.73:1 to 4.1:1
- My tercel:: 86 Tercel Wagon 4WD
mine's an '85 and the wiper lays horizontal at resttoughtercel wrote:ohh boy I call this fun !
rome on the edge.
Three types of Alternators in two amp ranges 70? and 90 amp, Two type with external voltage regulators. One uses a black Bosch regulator box and one uses a fuse-able link coil pack box thingie(found on my 84 SR5 Canadian model), Pain in the Arse BTW and are not swappable/interchangeable.There are also two types of alternators (one with an internal regulator and one without), and some also have apparently a gear reduction starter, but I do not know if that by year, or just a random production option.
Additions:
Pre-May of 85's have flip flop mirrors(the flip back or forth depending on which direction you hit something, much like early 80's jeeps)
Factory Tape Deck option and Sun roof option for 85+
85 and newer have a flexable filler gas tank connecting tube while previous years do not(Solid tube).
Pre 85,-65mph speedo, Post 85,-110mph speedo. (Reaganomics?)
Post October 85 went to an updated/improved oil pump(all Toyota)
Power window/locks option for 88,Manufactured Jan 88 for Toyota Canada. The last few LHD T4WDs made(Yes, I have seen one in person!)
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
85 Toyota MR2 (Blu)
Good call Synth, I have heard there were factory tape decks in '83, though I have not seen them. Also the speedo change was from the stupid national 55 mph that Pres Ford forced on the country (perhaps unconstitutionally) that Regan had lifted. Though 110 mph in a 62hp little boxy wagon I think is more than optimistic.SynthDesign wrote: Factory Tape Deck option and Sun roof option for 85+
85 and newer have a flexible filler gas tank connecting tube while previous years do not(Solid tube).
I was at the local yard today and found another difference: the grab handle over the passenger side seat is a different style on '85 and newer.
