oo oo that smell
- My tercel:: 1984, Toyota, Tercel, SR 5, Push Guard, Fog Lights
oo oo that smell
I've been smelling fuel when lately when I've been getting back into the car after running errands/running the tercel. Ideas?
Re: oo oo that smell
Leaks? Look for obvious ones.
Check your oil for a gassy smell. Fuel pump dying off.
Check your firewall for a semi-fresh oil slick right behind the fuel pump. Pump dying off.
Look for carb weeping out its gaskets.
look at all the fuel lines, especially where it could drip on the exhaust manifold. Best find the source, it could be a safety hazard. There is a diaphragm just behind the throttle bell-crank that sometimes weeps a little bit onto the heat shield causing the smell. Mine does that, but it is never very much, more a nuisance then a hazard.
2 places I've seen leaks:
* the large tube going to-from the canister being "melted"
* gasket in the carb...tighten screws?
- My tercel:: 1987 Tercel SR5 4WD Wagon
Also could be where fill pipe enters gas tank. I've seen them rotted out there.
Thanks guys
