So, when I installed two new horns to replace Goldie's mewing emanation, I worked up the diagram.
I used one each of Blazer (Fabrizio en Italia) brand high and low tone bugle type horns. I think they are about 112 +/- dB, and each cost $15 at AutoZone; I did not pop for the 132 dB version at $20 each. Two of the same tone would be equally good - my ears cannot detect much of a difference between the two sounds...
I mounted one in the OE position and the other in a similar position in the opposite fender. I used 14 ga. wires and regular male and/or female connectors. It was female spades into the OE "connector" for the OE horn.
I used a 40-amp relay and a 30-amp inline fuse holder. When I called Pilot, the importer of the Blazer horns, no one knew what the amp draw would be...but guessed that 10 amps would more than cover one. I doubt I'll ever add a third horn, but I'll be covered - just substitute a 30-amp fuse.
Incidentally, I checked the voltage at the OE horn - it was something in the 4+ volt range as I recall; going direct to the battery, the horns are getting 12+ volts - so they ARE louder using this method.
I also tried hooking up both horns to the OE wiring to see what would happen: Nothing happened; neither sounded, so I guess it was too much of a draw (at least I did not fry a fuse or wiring - lucky, but don't try it - just in case...).
Anyway, to the ohm-innocent, here it is!
