ARCHINSTL wrote:This is very interesting (although hopefully I will never have to use the info!).
Please continue with this discourse as you discover more.
The only engine in which I installed bearings was an ancient BMC "A" over 40 years ago - it wasn't that precise in those times...
Hey Tom,
I think the take home message for me was to plastiguage everything. My results were just the same as Splatterdog's - just under .002" clearance using aftermarket bearings. And I couldn't really see a difference between the #2 and #3 standard bearings. Their precision is amazing.
Here's a another thing. There are 2 different rod bearing inserts for the 4A engines. The earlier type (used in 4A engines until 1984 or something) are the same as the 3A and are quickly distinguishable by the smaller 12mm rod nuts. The later 4A engines have 14mm rod nuts. The only difference between the inserts is the width of the locating tang - it is narrower on the later engines to clear the larger rod cap studs.
All the carburetted 4A engines seem to have flywheels with 6 bolts. I found a 1988 Corolla with a DOHC engine with a 6 bolt flywheel. I couldn't use the head but I think the lower end would have fit under the 3A head.
I had a BMC A in an 850 mini. Crude, but fun.
![Very Happy :D](./images/smilies/icon_biggrin.gif)
I also had a BMC C series engine in a big Healey - Crude and more fun.
Cheers,
Shawn
