a question about heads..
thebigbread
Post by thebigbread »
Ive been wondering this for a while...
If all A-series engines (4age, 7afe, 3ac, ect) use the same bolt pattern for their heads, does this mean i could possibly swap a twin-cam head on my 3ac?
of course, id need a new timing belt, but it could mean a considerable gain in HP.
1984 2wd wagon, "bottle rocket": http://www.myspace.com/1984tercel
1995 Isuzu TFR-S, "Shorty": no cardomain page yet
I think someone has done this, I remember reading about it on the list some time ago. Several issues however, you have to make sure the valves clear the top of the bore since the bore is smaller diameter. It likely would have low compression because it would have a larger clearance volumn (you could put in flat top pistons available from Sealed Power, and mill the head to off-set this). You would have to workout the correct valve timing. Plus the same issues with the distributor coming off the back of the head, and making a custom exhaust header, induction system, etc. If I was going to do that much work I would just go for the full 4afe/age conversion. It would also end up being quite expensive I think.
thebigbread
actually im already saving up for a 4age swap, i was just curious.
well, in other words its too much trouble for too little gain, right?
shogun
Post by shogun »
im going back to boost, at the end of the year, right now collecting parts to get the job done right
ill tell you how it did work out
