Bumpers
Depending on where you are, you might get ticketed, also, it could weigh a huge amount.
If you do do it, incorporate a bull-bar up front and a trailer hitch in the back. Not really for heavy trailer hauling (unless you reinforce forwards) but in case you need to get pulled out, you'll have a good tie-in point.
I've got the same game plan coltarms, I dont have time to get into it right now, but I'll toss a few ideas I have up here as soon as I have a chance...
-1992 TCR10 Previa LE -Thanks Jetswim-
-1987 AL25 Tercel SR5 -Sold To Jetswim-
-2000 PL2000 Neon LE -Sold to spencersummerfield-
-1999 PL Neon SE -Stolen, recovered cut in half. R.I.P.-
-1987 AE86 Corolla GT-S Coupe - Sold (I want it back!)-
I think if you do go this route... Reinforce the structures further into the body. Not just the given bumper mounts. Extra rigidity, extra pulling/pushing power, etc. Heck, if I were you, I'd try and create an extra full-length subframe that extended a little past the existing "faux" frame-rails, on an even plain, both aiding in that rigidity and giving you an easy mount point for heavy skid-plates. Just watch for driveline clearance, be it driveshafts, CV shafts, or rear axle.
I know, a little beyond what you were talking about, but probably not a bad idea regardless.
Thats why I said make your own mounting points. Tubular square would work well I'm sure, with heavy gauge steel mounted across. You don't need plate for a skid. Unless you're driving around a bunch of IED's.
I'll say one thing about entry/exit angles...and that is I'd rather have the tow hooks at the back and whatever hits on the front HIT before the trans housing hits the dirt or rocks.
Call the bumpers an early warning system?
One serious smack of the trans on some solid rock isn't going to be pretty?
** I actually got to looking under the car and it seems the area right in the middle between the axles is right where the rear driveshaft support bearing is...so most likely the muffler or rear floorpans would hit something before the trans...I seem to be a little fixated on the trans?
