gearbox slack
jamiec
gearbox slack
Post by jamiec »
Does anyone here have gearbox slack (loosnes
like when accelarate and back off) :( in
there tercels? if so has anyone ever fix
the problem or do you all just accept it?
ive had two tercels that have had the problem.
Thanx for any info.
My first Terc had a really loose gearbox and it was really easy to select the wrong gear although it was super light and never grinded. This newer one has a really tight gearbox that has a hard time getting into first unless I go through second first.. I really want to get this fixed as my girlfriend has a hard time with it (and so do I.. but I love this car too much!).
Neither of them ever jumped out of gear or probs when backing off or on the power though, I think they all wear in different ways
perhaps you need to check your engine and gearbox mounts? does the engine move much when you have the hood (d'oh.... bonnet) open and you just use the carb to rev the car?
keith
Post by keith »
Only in fifth gear right? I had that problem until fifth just broke free, then it was a 4 speed. Fifth gear is an external gear located in the housing with the differential. I got the transmission repaired, then a couple of years (and 100k miles) later, it just locked up. Now I have a JDM trannie in it.
jamiec
Post by jamiec »
Maybe i should say it has driveline snatch?
like there is play in the drive line between power
on and power off.
