I'm selling the rims and coil overs off my tercel.
Rims -> 14x6.5" 'Mangles' polished aluminum aloy 4x100 bolt pattern, fwd offset c/w hubcentric rings. Tires are 195/60/14 H rated yokahama avid and have ~4k klms on them. There is about 85% treadlife left.
Coil overs -> Ground Control 0-4" drop (more if you remount the strut's spring retainer), Eibach springs, 2 sets rubber mounts. Will fit tercel, corolla, civic, accord, pretty much anything that has a 1.5"-2.0625" strut casing. There is about 1200 klms on them
$600CDN for rims/tires
$200CDN for coils
of course, I'm always open to reasonable offers
Together, they make any car corner like its on rails!!!
Rims are in my avatar pic and coil overs can be seen at http://www.ground-control.com under honda and coil overs.
E-mail - my_purple_rocket@hotmail.com for more pics and info.
Rims and Coil-overs
if you stil have the springs i would definately be interested if they fit properly and actually give a performance feel and are not just for looks
but how much is that in US dollars?
97 toyota tercel blackhawk(http://www.cardomain.com/id/Jonsblckhwk)<br><br>as soon as it goes to auction...<br>1986 toyota tercel HB<br><br>as soon as i have the money...<br>JDM AE101 4A-GZE BABY!<br><a href='http://board.tercelonline.com' target='_blank'>http://board.tercelonline.com</a> <br><a href='http://www.northeasterntuners.com' target='_blank'>http://www.northeasterntuners.com</a> <br><a href='http://www.toyrolla.com' target='_blank'>http://www.toyrolla.com</a> <br><a href='http://www.toyotanation.com' target='_blank'>http://www.toyotanation.com</a> <br>
did you use the ground control coilovers from the startlet or the tercel or the corrola?
whcih part # if you dont mind me asking
did you use the corollas rear suspension and disc brakes with the ground control coilovers ?
or did you just swap the breaks?:huh:
