ok, here we are.
I took the insurance off the Tercel because now I want it to be a wintercross car, ONLY, so now its time for a little more power than 60 hp.
check http://enormouslysideways.net/cams.html please and let me know what you thin for cam:
I want max power, screw drivability, I have a Weber 32/36, getting the head shaved as much as i can, pocket porting it, making my own tubular exhaust manifold and much stronger valve springs.
Thanks.
- R
Which Camshaft?
Which Camshaft?
I love my tercel
I think its .net..... At least Google says so... And you went "Way over my bandwidth, Didn't I?" Well, I'm telling you about it, lol.
I am curious about cams as well. Though I do want drivability, I want more horsies and torque. Not massively higher in the power band though. If I want something with peak torque above 3k, I'll go find a 4AGE lol.
Then you and I are going to struggle with the same thing Rasmus. I'm looking at tubular headers as well.
OK, to assist myself, I have tried a Desktop Dyno program...
check out http://calgaryvolvoclub.com/Dyno2000.zip
extract and save somewhere, run the Dyno2000.exe and check out the contents of tercel!.dyn
Thanks.
- R
Thanks.
- R
I love my tercel
i think you can get away with stock valvetrain with a 248 * duration cam, and also keep some fuel economy, but if you want power no matter what go for the 300 * and expect to break engines a lot
i can see the centerlobes are not that far apart so there would be almost no overlaping, schneider sells the springs and retainers, ill see where i can buy some titanium so i can make them if they dont exist
cam + titanium bits + aluminum rockers + lead foot = busted tranny and a whloe lot of fun
