THE 83 TOY BEATER REVOLUTION
as of before the swap.
the old motor 277+ miles on it
the new motor out of a 87 toyota corrola fx 230k on the clock
the motor was compleatly torn down, cleaned tanked crank machined, full rebuild kit installed and a remanufactured head put on it.
the tercel motor next to the new 4ac (thought it was a cool pic)
Awesome pics!! thanks for sharing! What sort of carb is that on your engine? I like the air intake setup you have; good design.
You know what is really cool about your new engine? You have a much much stronger block with the new 4A. That 7-rib block design is the same one they used with the supercharged 4AGZE. It's cool how Toyota used them from 87 on right across the board for all their 4A engines (4age 4agze, 4ac, 4af, 4afe, etc.). Of course, you'll have the smaller sized crank and rods.
Out of curiousity, how many bolts are there connecting the crank of your 4A to it's flywheel? I assume 6-bolt, but was curious if by any chance it is a 8-bolt? If it's eight bolt and fits in the tercel bellhousing, than you have found something special indeed! It could be used for a 4age or 4agze conversion too.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Really? Cool. Reason I was asking, is I'd like to do an intake setup similar to your, but without the snorkle. Right now my weber 32/36 dgev has a filter right on top of the carb that is sucking in hot air from my radiator. So, where did you get the aluminum piece that bolts on top of your weber? I'd like to buy one, and run a pipe from it to a source of cold air, and use a cone filter or something.83toybeater wrote:its the weber 32/36 dgev
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
http://www.jameng.com/products/index.phtml?section=14
its made by k&N on there site its 189 its a lot cheaper here
Whats the diff between this-99217.090: K&N remote air cleaner adapter
and this-99010.357: Redline remote air cleaner adapter.
The K&N is $85, the Redline Weber one is $100...
Could these be used to seat down Turbocharger boost?
Awesome!! Thanks!83toybeater wrote:http://www.jameng.com/products/index.phtml?section=14
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
