EL gear in 2 wheel drive
Just wondering if anyone has removed the lock out to allow the use of the EL gear in 2 wheel drive. I haven't really looked at if it is doable or not. It depends on if the EL gear is moved position when in 4wd. if not then it should be possible to just remove whatever lockout plate is used inside the tranny. This would be useful if lifting the tercel and then adding larger tires
1989 Toyota Van LE 4x4
1987 Toyota Parts Van 4x4
1974 Wellcraft Airsolt (Boat)
ASE Master Auto Tech.
The extra low gear is actually located on the shaft that comes out the rear of the transmission and I believe that it doesn't work in FWD because the transfer shift hub physically blocks the EL shift hub when it's in the FWD position. If you did get it to work, you would have rear wheel drive for that gear, and front for all the rest. Pretty cool.
