Weber fuel pressure regulator question
Hey guys, not sure if someone can help or not. Basically I'm trying to source a 4psi fuel pressure regulator to go with my Weber 32/36 DGEV. The tercel's fuel pump/pressure regulator feeds about 7psi into the Weber, but the Weber is designed to only run about 3-3.5psi. I understand that the 7psi can damage seals etc. after a period of time.
This fuel pressure regulator here looks suitable to me:
http://cgi.ebay.com/ebaymotors/Redline- ... enameZWDVW
Think it would work? Any ideas?
Nick
Nick
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
I originally thought this too. I've just recently read that Weber Redline HIGHLY recommends only 3-3.5psi for the carb. They say that it'll damage seals after a while otherwise. For $35 it's probably worth just installing one.Mac wrote:I dunno how damaging it would be..
the pump supplies fuel to the carb and the float raises up and down, when it goes up it plugs the hole and makes the fuel bypass the carb and go back to the tank.
the only thing that could potentially be damaged is the needle that the float controls
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Hmmm...so you're saying I'd be best off just installing an electric pump and regulator? Or...maybe less volume = better fuel economy? Means the engine might lean out a bit, but thats ok, I think it's running a little on the rich side anyhow.zipty842 wrote:A pressure regulator will also cut volume, which is what a weber really needs. Also, mechanical fuel pumps pulsate when they pumpand webers work best with constant pressure.
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
actually, the carter pump noted above without a regulator is the recommended pump for webers. filling the float bowl at a slower rate isnt gonna use any less fuel either, because the rate of fuel consumption is based on vacuum pull through the carb.
1986 Tercel 4WD SR5
1985 MR2
1983 Celica GT-S
1993 Toyota 2WD pickup "HILUX GT"
1985 MR2
1983 Celica GT-S
Less pressure really doesn't mean less volume....
At any rate, if there were a pressure regulator, I'd imagine it would smooth out the pulses significantly?
It will leak with too much pressure. Someone on here with one noted seeing that.
basically the way a pressure regulator works is by making the fuel line smaller here is a good source for weber info http://www.racetep.com/webtechpage.html
i will note that my dad has used webers for years with the factory toyota fuel pumps with out any problems. on models ranging from starlets to 4wd pickups.
1986 Tercel 4WD SR5
1985 MR2
1983 Celica GT-S
1985 MR2
1983 Celica GT-S
Thanks for all the advice guys. I'm really not a carb knowledgable person, I'm more of an efi type guy. OK, so I'm basically best off buying the carter pump that shogun uses, and not buying a regulator at all? I think I'll look into this. Thanks again!
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
If you're going to buy one, here is what Weber recommends. http://www.racetep.com/webfuelspark.html#webfuel
Good link Typrus; thanks! I'll look into that. It think that is definitely the way I should go. Sounds like the tercel's fuel pump is a POS as far as webers are concerned. I'll be interested to see how this affects fuel economy.Typrus wrote:If you're going to buy one, here is what Weber recommends. http://www.racetep.com/webfuelspark.html#webfuel
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Too much pressure can overload the float controlled valve...causing periods of high fuel levels? This would cause excess fuel use during idle and cruise?
![Image](http://www.nonags.org/members/nijqk/t4wd4.jpg)
Thats sort of along the lines I was thinking. Course as I mentioned, I really don't know much about carbs. Ah well, we'll see what happens I guess. Once I have the MR2 on the road 100%, then I'll pull the terc aside and do some work on it (including this fuel issue).takza wrote:Too much pressure can overload the float controlled valve...causing periods of high fuel levels? This would cause excess fuel use during idle and cruise?
Current:
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
