1983 SR5 Part out
- MrWrench
1983 SR5 Part out
Hey all, recently picked up this 1983 SR5. It's a bit too crusty to be roadworthy and the wiring harness is pretty badly damaged under the hood. Car has 168k.
Full part out. Everything must go. Comment, PM or email me at tercelrescue@gmail.com
I'm located near Grand Rapids, MI.
Parts that are damaged and no good:
Windshield (I do have another used one available if anyone is interested
Driver side door panel
Passenger door handle
Hood release cablr
Gas tank is probably horribly rusted inside.
Current sold parts list:
Tail lights
Blower motor
Mud flaps
Brake booster
SR5 body trim mouldings
Grill
Passenger headlight bucket
All seats
License plate frame
Keys and locks
Skid plate
Washer fluid and coolant overflow bottles
SR5 trim mouldings
Hood release cablr
Tail lights
Blower motor
Mud flaps
Brake booster
Grill
All seats
License plate frame
Keys and locks
Skid plate
SR5 trim mouldings
1983 AV-II Sprinter Carib.
- My tercel:: 1986
Re: 1983 SR5 Part out
Is the top steering column cover there.. Happen to know if the head would be salvageable..
Would love to have that tranny setup if you were only closer..Is that a factory gauge cluster on top of the dash? Might be interested if it is..Thanks
- MrWrench
Hey Carbine, I got your email as well.
What is wrong with your current cylinder head? The steering column top is there but it's grey in color.
I am currently on vacation but I will email you back in a day.
- My tercel:: 1986
Gray is what I need..Or any color for that matter..Mine is gone completely..I had to remove it once and it was so brittle it practically crumbled into pieces..
I just had my head worked on..It was pretty warped..I had a Machine Shop mill it..But it had a pretty good bow on the topside too..My Machine guy thinks it will be OK..I am skeptical the Cam and Bearings will have a very extended life myself....But he is a well respected and experienced Machinist. So I am going to believe him for now..
What about the incline gauges on the dash? Yes keep in touch please..Thanks Bruce
- MrWrench
Carbineone1964 wrote: Wed Aug 07, 2024 6:25 pm Gray is what I need..Or any color for that matter..Mine is gone completely..I had to remove it once and it was so brittle it practically crumbled into pieces..
I will carefully pull it off the car tomorrow. The top and bottom are in good shape. It is for a non-tilt column car, just as a heads up.
I responded to your email as well.
Let me know if you're interested and I can have the parts removed and shipped this weekend.
- My tercel:: 1986
I am thinking the top side might be the same even if it has tilt.. The tilt lever only seems to be proprietary to the bottom half only..Maybe I am wrong though..
I think you are wrong...
- My tercel:: 1986
You know that for sure, or just think that? Thanks
I'm pretty much sure- maybe someone else can chime in?
- MrWrench
By a quick visual inspection, it appears they are the same. I have this one removed and will check with one of my tilt cars tomorrow.
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
Hi MrWrench, I see you're parting out some stuff! I'm looking for a good 3 port vacuum advance, maybe a whole distributor if I have to. It's for a 1985 California emission 2wd tercel hatchback with the 5 speed. Thank you, i hope all is well for you!
- MrWrench
Hey man, I have a few distributors but unfortunately nothing with a functioning vacuum advance. I tested all the distributors I have a few years ago and only found one functioning one which I sent to someone who was looking for it. I believe you can find new ones on eBay but they're fairly expensive.Familyguy78 wrote: Sun Mar 09, 2025 10:37 am Hi MrWrench, I see you're parting out some stuff! I'm looking for a good 3 port vacuum advance, maybe a whole distributor if I have to. It's for a 1985 California emission 2wd tercel hatchback with the 5 speed. Thank you, i hope all is well for you!![]()
Let me know if you need a distributor still, I can send one out!
- WheelDrummerManiac
- My tercel:: '85 Toyota Tercel SR5 Wagon
Hey there. Don't know if youre still parting out or if it's all gone already, but im interested in that skid plate. I though I found a manufactured one online but I was mistaken. I want to take mine offroad more but im worried about busting a hole in the oil pan and other stuff. Also interested in that passenger side front running light if you still have it.
Winter comes, the car will rust. I'll start it up, it'll always run a little rough. - Good Kid
