Water pump housing for 1985 wagon
Danthebiker
My tercel:: 1985 4wd auto
Post by Danthebiker »
I need to find a water pump housing, AKA a water outlet housing. I am not a super experienced mechanic so I am not exactly sure what it is called. I did some research and found it listed as either. It is the part that both the water pump and the thermostat housing bolt to. I was installing a new thermostat today and I went to tighten up the thermostat housing and the cast aluminum part that it bolts to snapped before the bolt tightened up. Please let me know where I can find one.
Toyotise
My tercel:: 1983 4WD DLX. 1986 4WD SR5
Re: Water pump housing for 1985 wagon
Post by Toyotise »
You can get a new one on Rockauto. I have one in my parts supply stash, I can’t vouch for its quality as I’ve never had to use it. But it’s just a chunk of cast aluminum so not too much to go wrong there… It’s like 15 bucks.
Keep it Stock; Live Long.
Paul
Post by Paul »
Engine Water Pump Housing is part #16100-1908677. Used on the 1984-1988 Tercel, it might take some salvage yard searching. Maybe a request on the FB page might turn one up. I think new ones contain unobtainium.
