4wd ->94 coupe
- My tercel:: 94 2door 5efte tercel paseo steering and suspension carolla gears
4wd ->94 coupe
So 94 coupe built 5efte 5 speed and paseo steering and suspension. I do not exactly race the car but I live in a town where theirs plenty of empty roads cops are pretty cool about us launching on and stuff between lights and stuff like that. Would it be worth doing the 4wd swap for that extra fun factor how fragile would the system be I'm aware the 4wd on dry pavement is a big no no BUT if you do it to go as straight as possible since that's the goal would it hurt and how fragile are the diffs and axles ?
Re: 4wd ->94 coupe
94,
Likely a HUGE project that would require serious build skills and $$$. Gen2 have longitudinal engines, I’m sure yours is transverse. No “tunnel” for rear drive shaft IF you found a way to get your motor longitudinal with the transmission. Nobody knows for sure, but the general consensus/guess is the trans/drivetrain might be good for 100 hp. However, if you’re hammering it, who knows.
PS - the 88’-92’ AWD All-trac would be a more likely candidate for swapping drivetrain.
