Engines + trans for sale. - Grand Rapids, MI
MrWrench
Post by MrWrench »
Hey all, I need to clear out some space.
I have for sale a 207,000 3A-C. Compression numbers:
Cylinder 1: 135
Cylinder 2: 140
Cylinder 3: 140
Cylinder 4: 142
Has new cam/crank seals, new valve cover gasket, new valve stem seals, doesn't leak enough to leave drops on the ground. But she does burn a little oil. About a quart per 3000 miles, but if you drive it easier than have. It would probably burn less.
Good for a rebuild or to put a car back on the road.
The engine has been ran hard but always keeps going. No carb, no crank pulley.
$50.
I have another 3A-C from an 86. this car has been off the road since 1996. It's a little bit crusty but it only has 162,000.
$100.
I also have a transmission with no diff. The diff was pulled for another car. I'm pretty sure it was from an 84, but I cannot recall.
$SOLD
Local pickup in Grand Rapids, Michigan or delivery within 5 hours of GR is available for a little extra.
No shipping: I do not want to deal with the hassle.
1983 AV-II Sprinter Carib.
