Should I buy parts for a 86` or 85` if i got a 87`?
Zidderser
My tercel:: 1987 Al25 DLX 3AC 71HP
Post by Zidderser »
hi, as subject suggests, does that matter and/or can/should I mix between those two years?
I am buying transmission parts so they need to be spot on :)
Thanks!
"Pleasure is spread through the earth in stray gifts to be claimed by whomever shall find"
Source: Ash Bandicoot (random guy I found looking through comments on Facebook)
Greetings From Sweden :D
Re: Should I buy parts for a 86` or 85` if i got a 87`?
Yup, almost everything from both 85's and 86's should work for your 87. Headlights and grills are the only thing that are different for 87's.
I'm not sure exactly what month the diff ratios change in 1985. Worth doing some research on here.
Nordical25
My tercel:: 1x86, 2x87
Post by Nordical25 »
Mattel wrote: Wed May 03, 2023 6:07 pm I'm not sure exactly what month the diff ratios change in 1985. Worth doing some research on here.
I think that diff ratio changes with cars that have VIN around 150000-168000. My oldest Tercel had VIN around 168000 and it had already newer diff ratio.
Zidderser
Post by Zidderser »
yea I have heard about that before, i have this cart in rockauto now, any idea? seems to be the same part number but different description.
download/file.php?mode=view&id=14147
SirFoxx
Post by SirFoxx »
RetroGrade wrote: Sun May 07, 2023 3:23 pm
clutch has nothing to do with the diffs. when shopping on rockauto for the 87-88 year tercel, its best to shop under the 1985 year as to not accidentally get parts for the 3rd gen tercels.
viewtopic.php?t=16285
1982 4dr Tercel (RIP)
Post by irowiki »
Zidderser wrote: Sun May 07, 2023 3:23 pm
In that case it's just separating out the SR5 and DLX the part is fine.
Nordical25
AISIN CKT010 works fine in Euro Tercel. I have installed one kit into mine and that one works well.
And for some reason every Euro Tercel is DLX. SR5 was never introduced in Europe but we still got a lot of SR5 parts like inclinometer and wide side moldings. Tacho cluster was also introduced in many European countries excluding Finland.
that clutch listing does not indicate if it for a 4wd wagon for the '87. Those may not be the same kit, if it is not the 4wd wagon, it is a different clutch assembly than for a 1986 Tercel 4wd wagon or FWD sedan.
in 1987 model year the FWD sedans and hatch back got a total redesign, different engine and trans mounted transversly. They kept the 4wd wagon the same for 87 and 88 model years, that would be in common with the '83-86 sedan, hatchback, and the 4wd wagons.
Be careful when ordering any parts for the '87-88 4wd wagon, almost none of the parts are interchangeable with same year FWD hatch back or sedans, and many parts houses do not know that and their catalogs often just lump the 4wd wagons in with the others.
