WTB LF Drivers Window Regulator
Richard164
My tercel:: Looking at 86 4WD DX
Post by Richard164 »
1986 DX 4WD Wagon. I need a drivers side manual window regulator. In good working condition. The shaft on mine is very loose, turns freely but the window doesn't move. Something is stripped. Thanks Richard
Re: WTB LF Drivers Window Regulator
The drivers window regulators tend to wear out on these cars so they can be a little difficult to find. I would remove yours first and see if you can't repair it (I've done this numerous times), and if it can't be repaired, try looking on car-part.com. It searches all the auto wreckers within whatever distance you specify.
Richard164
Is the Left Rear regulator the same as the Left Front?
rer233
My tercel:: Multiple
Post by rer233 »
Definitely not!
Richard164
I found an era correct Toyota pickup regulator on Amazon for $12, took off the gear and winder mechanism andcwelded it yo my old arm. Works perfect now.
BL8R29
My tercel:: 1985white
Post by BL8R29 »
Richard164 wrote: Sun Apr 09, 2023 4:43 pm I found an era correct Toyota pickup regulator on Amazon for $12, took off the gear and winder mechanism andcwelded it yo my old arm. Works perfect now.
What did you search?
Thanks!!
