Feeler post here…
Working on consolidating homes and dont need all the vehicles I currently own nor all the projects…
Always wanted one so when i was able to find one I could afford I purchased it and stored it for 18mo before getting it to me. It had the standard blown transmission input gear..
Came w/a bunch of parts I installed plus did more since i was there…
#1
The good-
1987 sr5, 4wd 6spd, sunroof, AC vehicle, ps
Replaced struts, shocks, lower ball joints, tie rod ends, cv axles, seals, discs, pads, drums and shoes all new, transmission replaced.less than 150 mi ago
Aligned and drives straight (stops awesome thanks to new brakes)
Has new snow tires
Drives great, only had her up to 70 or so and did just fine
Stock carb that likely needs rebuild, (idles a little high then will not want to idle for 5 min or so before running fine again) have rebuild kit just havent started that yet.
Sunroof works! Has rear cargo cover
Currently has ski/snowboard rack as well as bike rack mounted
Spare clutch cable, flywheel came w/car so will transfer with as well, bought timing belt kit as well as replacement ps pumpas it was leaking (due to sitting) but has since stopped
Interior in surprising good condition with minimal wear on drivers seat, dash is immaculate w/no cracks.
Windshield no cracks
Bad- 269k
Dent in rear lid and pass rear corner,
Prior owner pulled stereo so no tunes at time of writing this.
#2
1986 standard gold terc I got for the motor, 128k. 4wd, body is rough
Transmission is blown.. haven't dropped the trans bought it for the motor
Have 2 (yes 2) 6spd transmissions (plus the blown input trans) from the ‘87 so 3 6spd 4wd transmissions 2 pulled from wrecked tercels, one from another ‘86 other year unknown.
Have other misc parts to go along with these. Rather sell as packaged deal if at all possible.
Dont have to sell but would like for them to find a home that will love them.
reach out if interested and serious.
2 tercel ‘87 sr5 and 86… spare transmissions Boise Idaho
- My tercel:: I don’t own one yet
Re: 2 tercel ‘87 sr5 and 86… spare transmissions Boise Idaho
Hi I’m interested what are you wanting for all ?
Thanks Jim
970-250-2849
Thanks Jim
970-250-2849
I assume these are long gone, but I sent you a PM just in case the blue 87 is available
