These are some pics of my D16Z6 that I built up for my Honda Del Sol. I put higher comp pistons in it and had a mild porting and a valve job done to the head. The compression ratio is about 12.3:1. Very high but it runs good on 93 pump gas, but it does run even better on Turbo Blue gas. I picked up a 5 gal drum of it one day and dumped that into my tank. Big difference.
These are the new pistons, they are from a D16A1 (88 Integra).
Random pic of the cylinder head.
Pistons inside the block.
Random engine pic of it on the engine stand.
Ready to go in my Del Sol.
Inside the engine bay.
All done.
Some pics of the engine I built for my Honda...
Daily Driver:
1988 Toyota Tercel SR5 4WD
3AC 2BBl Downdraft Carb
Project Car:
1993 Honda Del Sol Si
D16Z6 Head/Block
D16A1 Pistons (C/R 12.3:1)
Project Car:
D16Z6 Head/Block
VERY Nice!!! Honda engines are so well engineered! It's amazing how efficient they run. It's weird seeing an aluminum block though!
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
oh yeah, honda has awesome engineering with their engines. when i bought my new pistons I was going to balance the pistons and my old connecting rods. I checked the weight of all the pistons and they were the exact same, then i checked my connecting rods that i was reusing and they all weighed the exact same. i was shocked. later on i found out that honda pre-balances their pistons and stuff at the factory.
Daily Driver:
Project Car:
D16Z6 Head/Block
Project Car:
D16Z6 Head/Block
yep, I have D16A1 piston and rings in it. All of the bearings and stuff are from the stock Z6, same with the connecting rodsMac wrote:so are you running D16A1 parts in your D16Z6?
i have a 87 integra so i'm up on those engines.
Daily Driver:
Project Car:
D16Z6 Head/Block
Project Car:
D16Z6 Head/Block
the H22 fits nice in those accords. the accords and preludes have the same engine bays. i think you use the engine mounts from the prelude. but i could be wrong.
Daily Driver:
Project Car:
D16Z6 Head/Block
Project Car:
D16Z6 Head/Block
