Brake upgrade, steering, suspension, drive axles, bearings etc
Alexucf
Post by Alexucf »
Just ordered in a ton of parts thanks for the help especially Jhanek Szypulski can’t wait, gonna take the lead with me to tackle this project 🙂 I’ve created a parts list with part numbers if it’s help to the group.. rock auto / eBay / suspension.con i think it’s pretty accurate . hopefully I’m correct if not please chime in. This was all avail as of 10/20/22
FRONT BRAKES
96 Tercel drilled slotted rotors
Dynamic friction
- 63176949L
- 63176949R
86 Mr2 calipers
Nugeon ( includes bracket)
- 9901547A
- 9901547B
86 Mr2 front brake lines
Sunsong
- 2201520 x2
86 Mr2 front brake pads
PowerStop
- Z23242
REAR BRAKES
Drums
Dynamic Friction
- 36576014 x2
Wheel cylinders
Dynamic Friction
- 37576017 x2
Drum Hardware Kit ( per axle)
Dynamic Friction
- 37076002
Brake Shoes
Dynamic Friction
- 1901053000
BRAKE COMPONENTS
86’ Toyota mr 2 Brake Booster
eBay
86’ Toyota mr 2 Master Cylinder
Centric ( does not come with reservoir)
- 57536ky
86’ Toyota mr 2 Reservoir ( eBay )
DRIVETRAIN
Axles
Trakmotive
- TO8037
- TO8039
Axle Drive Seal
Beck Arnley
- 0523521
Front Wheel Bearings
Timkin
- 513002 x2
Front Wheel Seals
Skf inner
- 19643
Skf outter
- 20215
Rear Wheel Bearings
Timkin
- 88506Br x2
Rear wheel seals
Timkin
- 224210 x2
Rear Wheel Gaskets
Sourcing.
SUSPENSION/STEERING
Outter TieRod
AC Delco gold
- 45A0386 driver side
- 45A0387 passenger
Inner TieRod
Beck Arnley
- 101-4581 ( w/ power steering 5.37in) x2
Ball Joints
Beck Arnley
- 101-425
Front Struts inserts
Kyb
- 363037 x2
Front Strut Mount
Kyb
- Sm5067 x2
Front Strut bellow
Kyb
- Sb103 x2
Rear Shocks
Kyb gas -a-just
- kg4762 x2
Front Poly Bushings
Super Pro
Sway bar to Control arm
- Spf 1064k
Lower Control arm inner
- Spf1062k
Mevoteh
Stabilizer bar
- mk9542
garyfish
Re: Brake upgrade, steering, suspension, drive axles, bearings etc
Post by garyfish »
That's an ambitious undertaking to replace and/or upgrade all those parts in one BIG project! When you're finished, your Tercel wagon will handle SO much better and will be much safer to drive. Good luck, and keep us apprised of your progress if you can.
I did notice one omission from your extensive list of replacement parts, namely the bellows covering the inner tie-rods on the steering rack. As I'm sure you know, you'll need one bellows for each side, and I believe the passenger's-side bellows might be different depending on the T4WD year and model, and whether you have a manual rack or power steering. Rock Auto appears to have the necessary parts, including the "different" passenger's-side bellows for some applications:
https://www.rockauto.com/en/catalog/toy ... llow,11362
https://www.rockauto.com/en/moreinfo.ph ... 41&jsn=462
Just curious... what is the year and model of your Tercel 4WD wagon? Automatic or manual tranny?
Alexucf
Post by Alexucf »
It’s an 83 / manual / sr5 wagon , I’ll order some bellows if I’m missing those
Alexucf
Post by Alexucf »
Power steering. mevotech mk9321 I believe is correct
