Looking for a posting
Mogordo
My tercel:: 1983 SR5 Wagon
Post by Mogordo »
Hi, When I was previously perusing posts I found one on good vacuum set-up for Weber carb. Now that I actually want to refer to it to see if I can improve how the vacuum on my car is arranged I haven't found it. Does anyone know where it is? Or a good way to quickly find it? If I search "Weber vacuum" it shows at least 30 pages of results and those take a while to go through.
eightyfive4WD
My tercel:: 1985 Tercel 4WD 5 speed wagon
Re: Looking for a posting
Post by eightyfive4WD »
Mogordo wrote: Fri Sep 30, 2022 8:47 am Hi, When I was previously perusing posts I found one on good vacuum set-up for Weber carb. Now that I actually want to refer to it to see if I can improve how the vacuum on my car is arranged I haven't found it. Does anyone know where it is? Or a good way to quickly find it? If I search "Weber vacuum" it shows at least 30 pages of results and those take a while to go through.
Check out my post, #30, at the start of page 3 on my thread below; earlier this year I was battling some Tercel issues and in the process fixed my vacuum routing on the Weber.
viewtopic.php?t=15737&start=30
eightyfive4WD
I've bookmarked several more that are helpful for Weber set up and info. I recommend bookmarking these:
Installing a Weber Carb
viewtopic.php?t=1112
32/36 DGEV Weber carburetors
viewtopic.php?f=7&t=1021
Custom Weber 32/36 EGR Setup Info
viewtopic.php?f=4&t=9409
Mogordo
Post by Mogordo »
Thanks. I did bookmark those. Better start doing that with all postings I think I will want to refer back to at any point. I'll see if I can figure it out one these days and those will help.
