parting out 1983 sr5 wagon
- My tercel:: 1984 SR5
1983 sr5 everything except drive train is up for grabs. i want all these parts to go to use so im going to sell cheap, just make it worth my efforts. located in iowa if that helps figure shipping guess.
Re: parting out 1983 sr5 wagon
i can take more photos of anything you need like lights and seats plastic pits
- Tersailor
- My tercel:: 1983 toyota tercel 4wd deluxe
I Would love that inclinometer. sent a PM.
why are you parting it out? the body in the pictures looks decent, dent and rust free bodies alone are getting hard to find. it might be worth assembling the parts and getting it back on the road, a running tercel in the PNW will sell for $4000 and up, even if not perfect. that is likely way more than the part out value.
- My tercel:: 1986 SR5 4WD no mods yet just getting ahead of potential problems with a ton of preventative maintenance
How much for the door trim pieces or are they still for sale? I need driver side door and front fender pieces but would take them all. Also the little access door in the decklid, battery support, and sun visors. Sorry if this isnt how I'm supposed to message you I'm brand new here and havent figured it all out yet
rr,
Where in Iowa? I’m in NW Missouri.
- SirFoxx
no, they dont go for $4000. unless they are pristine, ESPECICALLY in the PNW where they are plentiful.Petros wrote: ↑Thu Sep 15, 2022 5:56 pm why are you parting it out? the body in the pictures looks decent, dent and rust free bodies alone are getting hard to find. it might be worth assembling the parts and getting it back on the road, a running tercel in the PNW will sell for $4000 and up, even if not perfect. that is likely way more than the part out value.
1985 4wd Tercel SR5 (RIP)
I need the drivers side window regulator. And the trim that goes around the steering wheel. 99% sure the 4wd uses the same ones as the 2wd. Should be a dorman 749-246.
- eightyfive4WD
- My tercel:: 1985 Tercel 4WD 5 speed wagon
Hello,razorrichter wrote: ↑Wed Sep 14, 2022 9:01 pm 1983 sr5 everything except drive train is up for grabs. i want all these parts to go to use so im going to sell cheap, just make it worth my efforts. located in iowa if that helps figure shipping guess.
I'd like to purchase the center console, as well as the inclinometer if it's still available.
Thanks!
- My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
Please I'd like the driver doors glass, let me know!
