WTB Drivers Mirror
SirFoxx
WTB Drivers Mirror
Post by SirFoxx »
Hello--
I am need of a drivers side mirror for my '85 2dr hatch. I shut the door and the glass fell out, exploding on the ground.
Thanks!
1985 4wd Tercel SR5 (RIP)
rer233
My tercel:: Multiple
Re: WTB Drivers Mirror
Post by rer233 »
Mirror looks different from our wagons- good luck!
SirFoxx
Post by SirFoxx »
rer233 wrote: Mon Aug 29, 2022 7:11 am Mirror looks different from our wagons- good luck!
only difference is they dont have the lever. they are all compatible with one another.
garyfish
Post by garyfish »
I believe the driver's side has a flat mirror -- not a special convex mirror like on the passenger's side -- so you should be able to go to an auto-glass business where they can cut a new mirror to fit and then use their special adhesive to mount it in place. You don't even need to remove the mirror housing to have this done and, if my memory serves me, it's relatively inexpensive. Good luck!
Familyguy78
My tercel:: 1985 Toyota Tercel 4wd Sr5, Fed emission but no cat converter. Manual transmission, with air conditioning.
Post by Familyguy78 »
Check rock auto, I just installed a new mirror glass from them and it's working perfectly so far
