clutch, clutch cable, and adjuster questions
There's something up with the clutch system in the 83 I recently bought but I have no experience with the tercel's clutch system so here I am.
The clutch slips. I've barely driven the car, just down a short road and back, onto a trailer and off it into my garage, but I noticed that going downhill it seemed fine and I was like, "great." Then when I turned around to come back I noticed the clutch was slipping like crazy and the car could barely make it up the tiny slope.
The automatic adjuster is within spec according to the FSM: the FSM says there should be at least 6 notches remaining on the "release sector" (what a weird name, I think something got lost in translation there) and that seems fine. When I depress the pedal, it moves about an inch (which is within spec) and then the pawl engages the release sector, at which point there are still 9 notches remaining on the release sector
I also removed the clutch cable and measured it. It was 39", which is actually a tad shorter than the new ones on rock auto that are 39.25".
So my question is, if the clutch is slipping which indicates it's worn out, and the cable is within spec, shouldn't the adjuster be max'd out? Like I said, I've never played with one that I know to be functioning normally so I don't have anything to compare mine to but it looks like it is working properly.
Thanks gang.
Re: clutch, clutch cable, and adjuster questions
A contaminated clutch disc or worn pressure plate could create your issue with the clutch disc within thickness specs.
Oh right. Good point. It doesn't seem to leak much oil (if any, no drips at all underneath) so I'm leaning more toward the pressure plate. Dang. I didn't want to have to drop the trans but I guess that's in my future.
I am betting clutch disc is worn
xirdneh wrote: Fri Aug 19, 2022 9:40 am I am betting clutch disc is worn
If the clutch disc is worn, shouldn't the adjuster be max'd out?
Either way, I will be getting in there and replacing the dang thing.
I have seen the pressure plate assembly on the cheaper imported clutches go weak and act like a worn out clutch. it can not grip the otherwise good friction disk.
if the presser plate assy spring is weak, the clutch cable/lever/pedal will all be in the correct location (since the disk is not worn out), but it will slip like a bad clutch disk.
I always test the springs now, even on a new pressure plate, just to make sure it is good, before I install it, or when ever I have to take out the trans or the engine for any other reasons. replacing the clutch is too big of a job to trust the clutch is any good that is in it.
