Adjusting idle on stock 84 carb
Nelsonrodgers
My tercel:: 1984, 4wd wagon
Post by Nelsonrodgers »
Hey so I’m still pretty new to the Tercel but I just drove home a newly acquired 84 white Tercel and The idle is a little high (at 1100 rpm) now that I drove it from Seattle to northern utah. I understand you need to turn the screw in the back and also the air intake. Is it possible I could get a solid explanation and maybe even a diagram. Thanks.
Nordical25
My tercel:: 2 4wd 1987's. One with 4a, other with 3a
Re: Adjusting idle on stock 84 carb
Post by Nordical25 »
Hi,
there is FSM found from here where you can check details:
http://tercel4wd.com/fsm/1985T4WD.pdf
Idle fixture is found from FU-28.
Nelsonrodgers
Thanks! That’s gonna help a bunch!
