-85 Tercel runs bad, 3A engine
Jonas.00
My tercel:: 1987, stock, with electric sunroof
Post by Jonas.00 »
The car runs well at idle, but jerks a lot when driving in all gears. if you suck in the vacuum hose to the distributor, the arm does not move, but it can be moved if you press the plate, but can a bad vacuum bell/membrane make the car jerk so much..
I just bought the car..
/Jonas
Re: -85 Tercel runs bad, 3A engine
I would confirm timing and good fuel delivery/carb function for starters.
Jonas.00
Post by Jonas.00 »
Hi!
It was the capacitor that was broken, yesterday it runs superbad, and this morning it was dead, så after puting on a new one its runs like a dream!
Jonas
The “condenser” on the distributor? Good to know, glad it is running better!
Nordical25
My tercel:: 2 4wd 1987's. One with 4a, other with 3a
Post by Nordical25 »
Hi Jonas, does your distributor have breaker points? Bad condenser sounds to me like a distributor with breaker points.
Jonas.00
Post by Jonas.00 »
Yes it has breaker points, and everything was perfect adjusted, but still runs bad, but when I put a new condenser on, it runs perfect, before it was like someone put the car on and of in superspeed :lol:
