No crank after head gasket repair
Cadendoo22
My tercel:: 1983 Toyota tercel sr5 4wd
Post by Cadendoo22 »
My head gasket blew a while ago and I replaced it but after putting the car back together it won't even crank. Everything has power and I tried jumping it. I can hear a click when I try to crank it but not sure what it is. I've never had problems with the starter or anything so this is kinda out of the blue
Re: No crank after head gasket repair
Caden,
Confirm strong battery and clean connections first, more than likely your issue if the car has been parked for a bit.
Cadendoo22
I feel real dumb rn. Turns out the starter was unplugged 🤦‍♂️
no worries, that kind of oversight happens to everyone. most will never admit to it.
One time I get a complete rebuild finally installed, connected it all up, and it started the first time. it ran for 5 or 6 seconds, but the oil light on the dash was not going out....I shut it down in a hurry. I just remembered I had not put motor oil in the the crankcase yet. that was a close call, I was about to leave it running, assuming there was something wrong with the oil pressure sender.
