1985 Tercel 4wd for sale (Glacier WA) Price drop for Tercel community
Jryan3
My tercel:: 1986 Toyota Tercel 4wd sr5
Post by Jryan3 »
Hi, up for sale is my wonderful tercel. Wev'e had so many good times together and it's managed it all very nicely.
It has lots of new parts and runs well
New-
*new crank and cam seal
*timing belt
*suspension all the way around including beefier pathfinder coils in rear/sway bar bushings
*thermostat
*new general altimax 14" tires
*oil change/tranny fluid changed
*spark plus/wires/distributor cap
Only bad worth mentioning-
*The interior up front is a little tattered
*doorpanels plastic inside is a little cracked
*no a/c but heat works very well
*Loud from exhaust leak Hole in exhaust under passenger seat
Asking $2600 firm
Located in Glacier,WA
Thanks!
-Jordan
Re: 1985 Tercel 4wd for sale (Glacier WA)
For those interested,
As an SR5, this is a M/T car with EL (in 4WD only), if an 85’ as indicated, should be 4.11 gearing.
Jordan - maybe you prefer to wait and only share with those truly interested, but pictures of the underside would be good, ie any rust around the trailing arm mounts (rear) or control arm mounts up front?
How long have you owned the car? total miles (or km) vs miles you put on? Any knowledge of service by the prior owner? particularly gear oil service on the transmission/front diff? Good luck with your sale and thanks for sharing with us.
Jryan3
Post by Jryan3 »
Hi Chris,
I will text/or email anyone truly interested more detailed photos. The picture uploading on the forum is a little frustrating. I have owned the car since 2015 put around 60,000 miles on it. Not sure honestly what was done to the car before i purchased it, I serviced the transmission and rear diff fluid 3 months ago. Tranny is in very smooth nice working order.
Odometer says 248,000 miles on it.
I guess I should also mention the speedometer doesn't work but odometer does.
Also it has a weber carburetor
Thanks- Jordan
MicronMilleniaPro
My tercel:: None yet
Post by MicronMilleniaPro »
Are you open to offers?
Hi Jordan, are you using the attachment tab to add photos to your posts or linking them from a third party site?
Yodaman88
Post by Yodaman88 »
Is this Tercell still for sale?
Jryan3
Post by Jryan3 »
Yodaman88 wrote: Wed Mar 23, 2022 6:44 pm Is this Tercell still for sale?
yes it is, message me if interested.
510
My tercel:: 1983 4WD - stock.
Post by 510 »
Pmd!
Neu
My tercel:: 1985 SR5 No Mods
Post by Neu »
Let me know if 510 buys it. I'd be pretty interested. I'm down in Portland so it's just a quick drive up there for me.
Jryan3
Post by Jryan3 »
Neu wrote: Mon Apr 11, 2022 6:11 pm Let me know if 510 buys it. I'd be pretty interested. I'm down in Portland so it's just a quick drive up there for me.
Hi! 510 messaged me but hasn't gotten back. pm me if interested still.
