Front mounted winches?
AlexArrow
My tercel:: 1986 Toyota Tercel SR5 Wagon 4WD
Post by AlexArrow »
I would like to see peoples front-mounted winch set-ups.
I have a small one I would like to have on mine, but want to see how others have done so. Sure looks like I would need to remove the front bumper, make and attach a 'frame' going to the front subframes, as I didn't see anywhere else and the bumper is all plastic.
Re: Front mounted winches?
There is a lightweight metal “body” wrapped by plastic for the bumpers. You are correct, a significantly more substantial bumper would be best for any winch set up.
simon84
Post by simon84 »
I have a winch mounted inside my grill. I did not remove the bumper to install it. I was dropping the cross member as part of a lift, so I tied into the top end of the 2 bolts for that ( just underneath the battery). I also added a piece of angle iron between the bumper mount bolts. So I did undo the bumper mounts but did not remove the bumper itself. There was a lot of fabrication involved in mounting this winch but I am happy with it.
I will dig up a pic and add it on here.
I can add more detail if anyone wants.
Also, I should mention that I have not tested it out yet under load. I really should give it a light testing. I have not managed to get myself stuck yet!
something like this would outstanding way to do it.
I also like the kind that uses a hitch receiver mount, you can have a receiver both on the front and the back. store the winch inside the car and mounted it where you need it on front or back. lower picture is receiver type mount
eightyfive4WD
My tercel:: 1985 Tercel 4WD 5 speed wagon
Post by eightyfive4WD »
My vote would be a receiver mounted winch, as Petros suggests. With weight being the most significant factor for most choices on the T4, I believe the receiver mount style winch gives a good balance of low weight and adaptability. You could fabricate hitch receivers on both the front & rear bumper, safely stow the winch in the back of the car, and hook it up to either the front or the rear when you're in trouble.
Nothing wrong with a larger steel bumper but I guess it entirely depends on how much abuse you expect your front end to receive.
Tercelouoffroad
My tercel:: 1986 Tercel 4wd
Post by Tercelouoffroad »
simon84 wrote: Wed Mar 02, 2022 9:35 pm I have a winch mounted inside my grill. I did not remove the bumper to install it. I was dropping the cross member as part of a lift, so I tied into the top end of the 2 bolts for that ( just underneath the battery). I also added a piece of angle iron between the bumper mount bolts. So I did undo the bumper mounts but did not remove the bumper itself. There was a lot of fabrication involved in mounting this winch but I am happy with it.
Hello
I would like photo of your winch bracket please :P
