pump discharge weight spring, for a 3ac carb
Pawstruck
My tercel:: 1986 4wd Hatchback Tercel
Post by Pawstruck »
Looking for a pump discharge weight spring that I can buy off of someone. Mine sproinged out of my carb, never to be seen again
Re: pump discharge weight spring, for a 3ac carb
I have a pile of used carbs, most are old junk carbs only good for parts. I am not sure what spring you need, but I am sure I have a spare, and I will be happy to send you one.
Is that the return spring on the lever, on top of the carb, for the accelerator pump? or post a picture of the carb with it circled. I just want to make sure I pull off and send you the correct part.
what in part of the country do you live?
Pawstruck
Post by Pawstruck »
Pawstruck
Post by Pawstruck »
Pawstruck
Post by Pawstruck »
It’s the spring in the photo. It goes with the larger ball bearing. Sorry for the delayed response. I’ll pay whatever. Im in North Central Washington. 98862 zip
I know that part. I will see what carb I can sacrifice for you, I should have something. when do you need it? I am rather busy with traveling and visiting friends and relatives right now.
Pawstruck
Post by Pawstruck »
I would be willing to buy the whole carb if you had one you can sacrifice. Our local yard in Omak just crushed their Tercels. The sooner the better, but whenever is convenient for you. I am so appreciative just for the offer. PO Box 385 Winthrop, WA 98862. I’ll Venmo or whatever you for shipping and the value of the carb
Pawstruck
Post by Pawstruck »
Hey Petros, is your offer still available?
yes, sure. I was out of town for several days last week. I need to dig around in the boxes of parts in my garage to find it. if you need it soon, I will make time to find a suitable parts carb for you.
Pawstruck
Post by Pawstruck »
I could use it soon. Let me know what I can pay you for it, and your time.
Thanks!
