Hi All,
I'm just finishing up front oil seals and a timing belt. When I went to start it and check over my work, I noticed that the electric fan goes on as soon as the key is turned. This is not the way it was, and I'm pretty sure the only electrical connections that I disturbed in this process were the fan plug and the temp sensor in the head. Any thoughts on why the fan wouldn't be working correctly?
Thanks in advance!
Radiator Fan On Full Time!
- tabercro
- My tercel:: 1985 SR5 4WD
-Tom
1985 Tercel SR5 4WD
1992 Volvo 740
1999 Volvo V70 R AWD
1986 Vixen 21TD
1985 Tercel SR5 4WD
1992 Volvo 740
1986 Vixen 21TD
- BaileySims
Re: Radiator Fan On Full Time!
If I remember correctly, the fan switch is on the lower corner of the radiator. Maybe you left if disconnected?
WAGON MAFIA.
Blood, sweat and beers.
- tabercro
I did miss that! It was tucked up out of the way and I forgot it when I put the radiator back in.
Thanks!
Thanks!
-Tom
1985 Tercel SR5 4WD
1992 Volvo 740
1986 Vixen 21TD
1985 Tercel SR5 4WD
1992 Volvo 740
1986 Vixen 21TD
That's a nice easy fix!
