Simple Question - Timng Belt and Front Seals Project
tabercro
My tercel:: 1985 SR5 4WD
Post by tabercro »
Hi All,
I'm wrapping up a timing belt and front seals replacement on my 1985 SR5 4WD. In the process of reassembly I've encountered a small bracket/clip that I don't remember removing. Photos below. Please remind me where this goes. Thanks for your help!
-Tom
-Tom
1985 Tercel SR5 4WD
1992 Volvo 740
1999 Volvo V70 R AWD
1986 Vixen 21TD
Re: Simple Question - Timng Belt and Front Seals Project
There should be two wires that wrap over the top of the timing belt cover. One to temp sender, the other to a sending unit right on the front. The clip you have typically holds those two wires as they wrap over the timing belt cover.
tabercro
Post by tabercro »
Thanks! Appreciate the response.
-Tom
1985 Tercel SR5 4WD
1992 Volvo 740
1986 Vixen 21TD
Good Morning Tom,
No problem, keep up the good work. I'm not sure where you reside, but we have a fantastic member (more often in the unrelated Facebook group) that has a few Tercels now AND a couple of the old Volvos. He is doing a lemons rally with one of the Volvos this year after taking his Tercel last year, a super guy.
