Hi All! Last time I did a tune up my cap and rotor was all burnt up. The points looked ok. I replaced the cap and rotor. That was last August. Any ideas on why they were charred? I was getting around 28mpg right after the tune up, now i'm back down to 20ish. I'm going to check it again, along with rebuilding the carb, but I just thought I'd pick peoples brains first......
Dave
Burnt Rotor
- My tercel:: '85 4wd SR5, 220k miles
When I replaced mine last fall, the points and rotor were just worn, not charred. I would think that it could get charred if there wasn't a very good connection between the rotors and the points, thus causing excessive sparking. I think I'd be surprised if you find that they are charred again on the new one.
'85 SR5 4wd, A.K.A 'Peach", 221k miles!
Don't be embarrassed. Points are an electro-mechanical devise for firing the coil. They are opened and closed by a cam on the distributor shaft located below the rotor. As to why your cap and rotor were charred..I don't know....sometimes they don't hold up well to all the spark they have to handle. Moisture under the cap might play a role.
As to your poor mileage...I strongly urge people to do a wet and dry compression test as this could give you a clue as to the engine's basic condition. Also check the ignition's timing advance. Check both vacuum advance diaphrams and the mechanical advance. Go thru the emission controls as they could affect the drivability. power and mileage. Other things to do/look for are.... cleaning and checking the functions of the external components of the carb (choke, choke opener, choke breaker, choke heater, etc.)....valve adjustment...make sure your brakes aren't dragging...tire pressures are not too low...etc.
I would do these things before tearing into the carb.
Hope this stuff helps.
Well, I did a quick compression test. All 4 cylinders read within 5 psi of 150. All the plugs were clean and seemed to be burning well. Looks good to me. I also tightened all the bolts on the carb....some were almost a full turn loose. I still plan on rebuilding the carb as it seemed to be leaking fuel around the base and at other spots.
