'84 Tercel 2wd wagon free parts
- My tercel:: 1984 DLX wagon
This car still runs well but has rusty floors and is uninspectable. I have many carburetors, distributors, fuel pumps, engine parts, 2wd transmission. Many good trim parts. Good hood, no rust . Deck lid good,surface rust. Tail lights very good. 4 white aluminum factory wheels, at least 8 steel wheels, 5 stainless trim rings - none perfect. Factory AC, Period correct roof rack, gray interior not bad. You pay shipping and handling only. The car and I are both in Vermont, but the car came from Florida 5 years ago. What do you need?
Re: '84 Tercel 2wd wagon free parts
do you have the "pizza cutter" type Tercel factory allow wheels? I have a project Tercel that has two of the factory alloy wheels, the rest of the wheels are mismatched steel wheels. I can use two of them. I need to check out if I need anything else.
I'm interested in the roof rack, (especially if it is a gutter mount), 1 carb, and the cover for the back area if available. Thanks
Does the car have adjustable intermittent wipers or cruise control?
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
Hi Pedro,
I guess I don't know what "pizza cutter wheels" are. I'll send you a picture.
Ernie
Ernie
Hi Zachary,
The roof rack is held on the roof with sheet metal screws. Where are you located?
Ernie
Ernie
Hi Professor,
Sorry to say my car has neither intermittent wipers nor cruise control.
Ernie
Ernie
- My tercel:: 1986 Toyota Tercel SR5. Completely stock
Where are you located? I’m interested in the hood!
Hi 86tercelOG,
I'm located in Pittsford, Vermont.
Ernie
Ernie
I'm in the 60041 zip code. I'm kind of chicken to drill through my roof though. I was hoping it had the gutter mounts.ernieclerihew wrote: ↑Thu Dec 03, 2020 1:28 pm Hi Zachary,
Ernie
that is the term to describ the early factory optional alloy. I am not keen on them, but many like the nostalgic look, and one of my project cars only came with two, plus the one in the spare well. so I need at least one, but I would consider taking more. I also need the center cap. attached is the picture of what I am looking for. they should weight about 24 lbs each, perhaps less.ernieclerihew wrote: ↑Thu Dec 03, 2020 1:16 pm Hi Pedro,
Ernie
Hi Pedro,
That is exactly what I have, painted white. I also have 4 center caps. These came from my daughter's 1983 4wd Tercel, a long-gone victim of rust, but I saved the wheels. Like I said, I'm new to the forum - how do we proceed from here and how many wheels do you want?
if they all match, and not too beat up, I suppose I can take the whole set. we can go to the Private massage part of this forum, and work out shipping, costs etc. or you can send me an email at petros98223@gmail.com.ernieclerihew wrote: ↑Sat Dec 05, 2020 11:27 am Hi Pedro,
That is exactly what I have, painted white. I also have 4 center caps. ... how do we proceed from here and how many wheels do you want?
easiest would be to find heavy card board boxes that they fit in (or cut larger boxes down to fit), included some extra layers for padding, and than weigh them to find out how much they cost to ship. likely USPS would be cheapest way if the box is not too large for them. it would likely be best to just remove any tires they might have and discard them if they are older than perhaps 4-5 years, old tires decompose and usually are not reliable. you would have to go to a tire shop to have them removed with their tire machine.
Before you spend any money, let me know how much shipping and costs for your troubles. to make sure sending wheels across the country is worth the cost.
- Mattel
I believe bryan thompson might have 3d printed centercaps. might be good getting the file off him.
Still offering, Ernie? I'm interested in that roof rack, but I wonder if you could supply pictures before I foot the bill for shipping to CA.
I'm also definitely interested in the driver front turn signal lens, the badge that goes on the tailgate, and I wonder if you have any transmission or engine mounts in your loose parts bin.
