Front Carrier Axle Bearings
Yaut
My tercel:: 1985 Toyota Tercel 4WD automatic, lifted 1.5", 15 inch wheels
Post by Yaut »
I haven't seen this documented anywhere but the bearings in the front carrier for either axle is listed as Toyota part number 90366-35002. According to the originals ones in mine, they cross to a Koyo (HI-CAP) 57272A-N or 57272AN
Yaut
Re: Front Carrier Axle Bearings
Post by Yaut »
Another carrier bearing used is Nachi E 32007 S1
Yaut,
I believe the Nachi designation would be E 32007 S1, where the S1 designation relates to heat treatment of some type. I couldn't easily find the same info on the Toyota part #, so I can't confirm they are exactly the same.
Amazon Ad
From Yoyopart.com
Interchange Parts for KOYO 57272AN
Brand Sku Type Name Relevance
SKF 32007C ROLLER BEARING SKF 32007C ROLLER BEARING
SEALED POWER F-32007C ROLLER BEARING SEALED POWER F-32007C ROLLER BEARING
TOYOTA 90366-35002 ROLLER BEARING TOYOTA 90366-35002 ROLLER BEARING
TOYOTA 90366-35013 ROLLER BEARING TOYOTA 90366-35013 ROLLER BEARING
CR 32007C ROLLER BEARING CR 32007C ROLLER BEARING
BOWER 32007C ROLLER BEARING BOWER 32007C ROLLER BEARING
TIMKEN 32007C Differential Bearing TIMKEN 32007C Differential Bearing
DT Components 32007C ROLLER BEARING DT Components 32007C ROLLER BEARING
Precision Seals & Bearings 32007C ROLLER BEARING Precision Seals & Bearings 32007C ROLLER BEARING
Yaut
Post by Yaut »
Oh thank you. I will update my previous post as to not cause confusion.
