I'm not sure if this is common with these old Tercels.
I find my radiator fan comes on a bit too late compared to my coolant temp, and doesn't really stay on long enough.
What could I do to adjust the point at which the radiator fans comes on and turns off without manually turning it on or off?
This is the only cooling problem I have left to sort out with my wagon. I have just recently replace the water pump, thermostat, radiator, and done fresh coolant. All of this already has made a big difference compared to when I first the car.
The radiator fan issue I described only really happens when the car has been idling for a bit.
Radiator fan adjustments?
- Kozuto_98
- My tercel:: 1987 SR5 Wagon
1987 Tercel Wagon SR5 4WD
- ALiveSR5
Re: Radiator fan adjustments?
Could it be the temperature sensor at the bottom of the radiator going bad?
- Kozuto_98
It's certainly a possibility, but it still seems to work fine. I'm mainly looking for a method to turn the fan on earlier and to stay on a bit longer
than it currently does.
I would consider replacing the sending unit mentioned. They may even have something with a lower switch point. If you are just watching the guage, I would slso suggest a temp measurement to confirm what the guage roughly indicates.
- Kozuto_98
Alrighty! I'll give that a try.
there is no adjustment, it is controlled by the sensor. could be the sensor going bad. they do not cost much. I would check out the actual on/off temps as specified in the FSM, and replace it if it is out of spec.
