¡Hola Tercel4WD!
In my desperate search for lighter 14x6 alloys (for 27" tires of course lol...) I started compiling all the info I could find on this forum (and others) and I created this living Google Doc down below.
The Definitive List of Tercel Compatible 4x100 Wheels
https://docs.google.com/document/d/1Oqi ... rz2payl7a3
Here are the OEM Tercel Wheel specs for comparison
Wheel Size: 13x5
Tire Size: 175/70r13 or 165/80r13
Center Bore: 54.1mm
Offset: ?
Pitch Circle: 4 x 100mm
The list is mostly complete and the gallery is a work in progress. If you have anything to add/correct please let me know and I'll update the doc.
Original thread with most of the info (kudos to takza and 83toybeater for putting in the earlier work)
viewtopic.php?t=52
Miata thread I "borrowed" info from
https://www.miata.net/faq/wheel_weights.html
The DEFINITIVE List of Tercel Compatible 4x100 Wheels
- My tercel:: 1983 Toyota Tercel 4WD SR5
'83 Tercel SR5 Wagon Overland Build Thread >>> viewtopic.php?f=6&t=14880
- GLet71
- My tercel:: '87 6-spd SR5 4wd Wagon
Re: The DEFINITIVE List of Tercel Compatible 4x100 Wheels
Currently:
Formerly:
Formerly:
