for almost the past week my tercel has been stalling on me a lot. when ever i come up to a stop and have the clutch pressed in with no gas most of the time it will just die. also when i let it warm up in the morning if i let it idle for a bit it dies aswell. i think the problem might be in the carb. i have about 134K on the engine and i know the carb has never been rebuilt before. please help. when ever i come up to a stop i have to give it a little gas to keep it running.
ill check those out. oh, will this work with carbs. i used to do this all the time to FI engines to check for vac leaks. i would get a can of carb and choke cleaner and spray it around the vac lines and if the engine starts to chug then the leak is right around there.
on F/I cars it makes the idle drop. if you spray a lot of carb and choke cleaner in your carb it will start to bog down and can even stall. i checked for any vac leaks and i could not find any. its really weird, when i push in the clutch and let the rpm drop most of the time it will just die. i think it might need a good rebuild or something like that.
