WTB: trans shifter parts
ftpiercecracker1
Post by ftpiercecracker1 »
Bits and pieces in the shifter column have made the stalk very sloppy and make finding 1st gear difficult.
Any help finding these parts or something thay will work is appreciated.
33555-16030 dust boot
33548-16010 bushing
33505-16010 bushing/o-ring thing
Im going to use RTV for gasket material.
Or if you know of parts from another vehicle that interchange.
I found this on ebay.
https://www.ebay.com/itm/fulcrum-ball-b ... SwEYBaUNwh
It contains every part i need, but its not specifically for a tercel. I thought maybe it was worth a shot, since a lot of toyota parts are used across multiple vehicles.
MrWrench
Re: WTB: trans shifter parts
Post by MrWrench »
Have you called your Toyota dealership? I have everything but the boot on order though my local dealership because it's NLA.
1983 AV-II Sprinter Carib.
ftpiercecracker1
Sadly my local dealership is not able to get any of the mentioned parts.
No luck on ebay either. Every online auto parts store ive checked lists all of them as discontinued and/or NLA.
The Professor
Post by The Professor »
Welcome to the world of obscure, obsolete Japanese cars! You can probably adapt something to work from another similar model.
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
garyfish
Post by garyfish »
A near-perfect aftermarket replacement for the rubber dust boot is available on Amazon.com at the following URL:
https://amazon.com/gp/product/B000FQ227I/
I've used these on a couple different occasions, when I was doing a clutch job on my T4WD's, and have been very happy with the fit, the quality of the rubber, etc.
The Professor
garyfish wrote: Wed Jul 03, 2019 7:54 pm A near-perfect aftermarket replacement for the rubber dust boot is available on Amazon.com at the following URL:
This is for the inner boot that attaches directly to the transmission, not the body-mounted rubber boot, correct?
Pics of how you secured it?
garyfish
Post by garyfish »
yes, it's the inner boot
don't have any installation pics... the rubber boot simply stretch-fits around the circular projection on the top of the tranny where the shift lever goes
jimcrazy
Post by jimcrazy »
these all-balls boots for 4-wheelers cv axles also fit good,about 20 bucks
Excellent! you have a brand and part number for that?
I was thinking of using a large section of inner tube with zip ties at both ends.
