My baby
Treleytercel
My tercel:: Toyota Tercel 1983
My baby
Post by Treleytercel » Wed Apr 10, 2019 10:57 am
:mrgreen:
Treleytercel
Re: My baby
Post by Treleytercel » Wed Apr 10, 2019 11:08 am
150 thousand miles weber I love it
Re: My baby
Post by Petros » Wed Apr 10, 2019 1:48 pm
welcome to the forum!
where are you from? car looks nice, interesting to paint the rear bumper. how did you come to own a Tercel4wd?
Treleytercel
Re: My baby
Post by Treleytercel » Wed Apr 10, 2019 11:13 pm
Salem Oregon and I met someone with it and didn’t know if I wanted it but now I love it and want to restore it.
Re: My baby
Post by Petros » Thu Apr 11, 2019 2:25 am
you have come to the right place!
looks like your are going to need a rear view mirror at least. how does it run, what else does it need?
Treleytercel
Re: My baby
Post by Treleytercel » Thu Apr 11, 2019 10:13 am
Well it ran great but then I got a engine leak and did the cam and crank seals and didn’t tighten the cam enough and it walk off half a inch now it won’t fire.
Re: My baby
Post by Petros » Fri Apr 12, 2019 6:09 pm
not sure what that means, did you do damage to the head/cam mounts?
Treleytercel
Re: My baby
Post by Treleytercel » Sat Apr 13, 2019 10:54 pm
I’m not sure i didn’t see any damage under the valve cover so I think I’m going to send it to my mechanic.
Treleytercel
Re: My baby
Post by Treleytercel » Tue Apr 16, 2019 5:27 pm
Almost done painting it
Re: My baby
Post by Petros » Tue Apr 16, 2019 11:52 pm
...did the cam and crank seals and didn’t tighten the cam enough and it walk off half a inch...
what does "walk off half a inch" mean? the cam pulling cam loose, or the camshaft came out?
what did you not tighten enough? the 17 mm bolt on the front of cam sprocket? or the 10 mm bolts on cam tower caps, that act as bearings for the camshaft?
Trying to understand exactly what happened, if you can clearly communicate that we might be able to give you instructions to fix it yourself. But with these cryptic and incomplete descriptions it is impossible to help you or give you any instructions.
you may have gotten the cam timing off when you removed the cam sprocket, it will not run if the cam timing is off, and that is an easy fix.
Treleytercel
Re: My baby
Post by Treleytercel » Wed Apr 17, 2019 3:19 pm
I need a cam I broke the tooth that holds the sprocket and a head gasket.
Treleytercel
Re: My baby
Post by Treleytercel » Fri Apr 19, 2019 10:27 pm
Do I put anything like rtv when doing my head gasket?
Re: My baby
Post by Petros » Mon Apr 22, 2019 6:43 pm
no! the head gasket should be put on dry, right out of the package. try not to touch the surface much, it has a graphite coating on it.
After surface sanding of both block and head, clean the top of the block, and the face of the head good. use solvent and paper towels, wipe vigorously, repeat until they come away clean.
install it all dry. you lubricate the threads on the head bolts, and under the head bolt washers only.
teranfirbt
Re: My baby
Post by teranfirbt » Tue Apr 23, 2019 9:20 am
To expand on what Petros said, lubricate the threads and washer *lightly*. Any oil that comes out of the threads will contaminate the gasket, all it takes is enough oil to coat the threads. If oil is dripping off of the bolt you have way too much. If there's oil outside of the thread crests you have a little too much.
For cleaning the threads in the block I like to fill them all with acetone and let it soak in for a bit, then I take a 45 caliber bore brush in a drill and thoroughly clean them out. Then another acetone soak, this time with some compressed air and a rag to blow out any shmoo (technical term). Last I thread a cleaned and brushed bolt in, it should thread in fully with zero resistance. If you feel any resistance, clean it again. If you can't get it with cleaning you may need to chase the threads with a tap.
Re: My baby
Post by Petros » Tue Apr 23, 2019 5:52 pm
exactly correct, clean the bolt holes out before you do the final clean of the top deck, there is no way to clean the bolt holes out well without getting solvent and debris on the deck surface where the gasket goes.
When I worked for a professional fully sponsored race team, we would chase the threads with the correct tap every overhaul. it was done carefully mostly to clean out any burs or thread damage, we did not want to cut any new material.
I think however, a good cleaning is all that is necessary normally. I made a thread cleaner by grinding two flat surfaces on a correct size bolt, and fully deburr it. I thread it into each hole, with solvent, and back it out. blow out with more solvent and compressed air, than repeat with bore brush several times. remember to carefully and fully clean the threads on the bolts as well, and inspect the threads for any damage. it can be cleaned up with a stiff wire brush, and if necessary a fine file for any damaged thread.
