Just wanted to share some of my recent tweaks to my daily driver/dog car, "Charlie."
So after I added angle iron to extend the stock seat I realized that I could put just about any seat I want to in the car. I found these sweet power heated seats out of a 2002 Nissan Pathfinder and I only had too modify one bracket to get them to fit!
Wiring them was a different story though. There were a bunch of wires and plugs under there so I took them inside to figure out what's what and I figured out which wires went to the airbag real quick!
Luckily it split right along the seam except for one tiny spot.
And I was able to remove the cover and resew it pretty well.
I'm glad I started with the passenger so when I got to the driver's I knew what not to touch. However, the driver seat had the automatic memory buttons and two additional motors for the seat pan so there were about 8 plugs and 40 wires under there connected to a circuit board. It took quite a while to figure out what goes where and which wires needed power and what not but I finally got it and didn't blow the seat up!
After I got them in and the power functions working I had to figure out where I wanted to put the seat heater switches. I was contemplating putting them in a logical place like right by the ebrake handle. Decided not to though as I didn't want to cut into the original trim and cause I'm going to be placing an ammo can over the ebrake anyway to have a larger cubby for the center console.
I was also in the process of installing an overhead console that I pilfered from a 1998 Isuzu Trooper.
And I realized that there was room on the back wall of the garage door opener cubby if I installed everything just right. So I ran my wires all over...a constant power runs to a switch in the blank by the shifter then to a 6 pole fuse block behind the stereo. From there power runs directly to the seat motors but also up to the seat heater switches in the overhead console then back down to the seat heaters. Power also runs up to the over head console for the maplights and the clock. This is the only pic I really took of the wiring:
It also shows the cuts I had to make in the headliner for the overhead console but I wasn't worried about it. I used the original headliner with a nasty waterline from the leaking roofrack (which is fixed).
Well I couldn't have that headliner looking so gross so I did something about it. I realize it's not for most people...but I love it.
The overhead console just looked too out of place for me so I decided to do something about that too.
Now I have a clock in the DLX...and MAAAAPLIIIIIIGHTS!!!
And here's the seat heater switches:
Oh, and I did this a while ago but never shared it...I cut a queen mattress in half like sandwich bread so it wasn't so tall.
Then templated the back end with the seat backs removed and cut it out.
Now my boy has the whole back end for a bed.
It looks a lot better with all the trim back in.
Thanks for looking!
