1983 Tercel 4WD wagon for sale. Louisiana
Allen
My tercel:: 1983 4WD Wagon
Post by Allen »
keith
Re: 1983 Tercel 4WD wagon for sale. Louisiana
Post by keith »
The front oil seal leak is a chronic problem on this model and easy to fix. I use a breaker bar with the right size socket on the front pulley bolt, wedge the breaker bar handle in the frame and hit the starter momentarily. The bolt comes off easy. An impact wrench also works.
Remove the pulley and harmonic balancer, then the timing belt and lower timing gear. Then just pick out the seal with a hook tool. Do NOT use the instructions for this seal from the FSM, too much work and an increased risk of damaging the new seal. Carefully install a new seal and while your at it, a new timing belt and tensioner.
rer233
My tercel:: Multiple
Post by rer233 »
+1- easy!
Seal Tool:
viewtopic.php?f=10&t=10455&hilit=seal
Xirdneh's video:
https://www.youtube.com/watch?v=fS3bAwwR43w
NWMO's photos:
viewtopic.php?f=2&t=12183&p=94192&hilit=seal#p94192
My tool pix:
viewtopic.php?f=16&t=12567&p=97224#p97224
Also from the preceding: "I forgot one item on doing the belt replacement: xirdneh had no luck using his impact wrench on the crank bolt - he went in with the extension and flex joint over the bumper - I went in with my impact wrench and the extension and flex joint under the bumper, and the angle was much less acute and the bolt popped right off."
