Clutch slipping?
Dumindu
Clutch slipping?
Post by Dumindu » Sat Aug 11, 2018 11:40 am
In my car after an engine repair (where clutch cable detached and re-connected), agears on the stopped car can be shifted without depressing the clutch.
Also car stops when going to move the car.
Is it a sign of a slipping ?
If so, can it be corrected by release the tension on clutch cable?
Re: Clutch slipping?
Post by xirdneh » Sat Aug 11, 2018 4:20 pm
If they pulled the engine they probably messed something up with the clutch or throwout bearing. Slippage usually happens in higher gears. The fact that you can shift without depressing the clutch pedal tells me something got messed up or installed wrong
Post by xirdneh » Sat Aug 11, 2018 4:26 pm
Check clutch cable connection in engine compartment at fire wall to make sure it is inserted into fire wall correctly. It could be hung up there or at engine under the distributer \ over starter. That could make cable wire too tight
Dumindu
Post by Dumindu » Sat Aug 11, 2018 5:29 pm
Thank you for your advice.
Post by Petros » Mon Aug 13, 2018 9:00 pm
if your clutch is not fully engaging, which would allow you to shift it without using the clutch pedal, that could be why you have no power to climb hills. clutch is not fully engaged.
though that would not make it spit out of the carb, that would be caused by something else, likely timing.
