My dad is selling his 4WD Tercel
-6 speed MT
-FWD or 4WD
-Engine and Trans got rebuild couple years ago (can't remember)
$900
604-299-8048
<a href='http://www.dorikaze.com/attachment.php? ... 3147&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 7&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3148&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 8&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3149&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 9&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3150&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 0&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3151&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 1&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3152&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 2&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3153&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 3&stc=1</a>
<a href='http://www.dorikaze.com/attachment.php? ... 3154&stc=1' target='_blank'>http://www.dorikaze.com/attachment.php? ... 4&stc=1</a>
FS: 4WD Tercel
- Mattel
Yeah, you need to be a member of that forum to view the pics. Its worth your time though, it's a good forum.Mattel wrote: Do you need to login?
Is there a way around this
cheers
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
- simon84
where in BC are you?
Is that really a 4A under the hood? How does it run, how is the power?
-simon in Calgary
-simon in Calgary
Power=more? lol. It is quoted by Chilton's as such
Torque (Ft/lb) Horsepower
3AC- 75@2800 RPM 62@5200 RPM
4AC- 85@2800 RPM 70@4800 RPM
Well check that out... The 4AC really would be a better match to our 4wd... Lower RPM for more HP, same low RPM for more torque... Heh. Just for kicks, here's the 16 valve 4AGE
4AGE- 97@4800 RPM 112@6600 RPM
Lol. Doesn't hit its torque peak (only 12 over the 4AC) till the RPM where the AC's hit their HP peak. In other words, the 16valve would not work so hot for our 4wd. The 20v on the other hand....
4AGE (Sil) - 119.34@5400 RPM 160@ 7400 RPM
That Silvertop quote off of <a href='http://www.geocities.com/MotorCity/7177 ... gines.html' target='_blank'>http://www.geocities.com/MotorCity/7177 ... es.html</a>
So almost double the torque at about double the RPM from 3AC to Sil 4AGE. Over twice the HP at a about half again the RPM's.
I'd really have to overlay a dyno graph for either engine on the same dyno, same day, same conditions, to see how they compare for low-end torque. My earlier comparison was based on a graph from another source, without a graph for the 3AC, just those Chilton numbers.
If I can get $30 by the 1st of October, I'll try to throw my baby on the dyno. Lol. I can just see me dancing around as I hit 63 horses and all the diesels around me just staring at me like I'm on crack. lol.
In my opinion, a 4AC would be a good improvement on a 3AC, ESPECIALLY considering that there is a little of an aftermarket following for them, as some were employed in the RWD Corolla. Along with the ability to fit 4AGE parts in some places. If you could maintain its low-RPM torque ability, then all the more power to you.
There I go, getting carried away... :ph34r:
Typrus -
This is a great line:
Good sense of humor.I can just see me dancing around as I hit 63 horses and all the diesels around me just staring at me like I'm on crack.
