My daily driver recently developed a very annoying problem, it is very difficult to start when below freezing. It has never acted this way before.
about a month ago I noticed it was more difficult to start from cold in damp weather, with a lot of sputtering. I replace the spark plug wires and distributor cap and the problem cleared up, started almost immediately, even when stone cold.
But now when it is really cold it has to be cranked and cranked, with no signs of spark at all, until eventually I get a sputter, than a few more sputters, and than a very slow to spin up start. once running, it appears to act normal. After it is warm there is no indications of any problems at all, no flat spots, runs strong and smooth.
Even when coasting down our long hill in the morning, usually the fast spinning allows it to start almost instantly, but not now. It has to be spun up for a long time, sometimes I even come to a rest at the bottom of the hill and have to use the starter to get it running. No vacuum leaks, and choke appears to be operating normally.
I am going to try a few things, like use some starter fluid in the intake. that would indicated if it is weak spark or poor fuel delivery.
Any other suggestions on what to check?
Very diffcult to start in freezing weather
Re: Very diffcult to start in freezing weather
My 81 did that when the choke did not work properly, but that carb was screwed up and a replacement carb fixed it.
- dhally
- My tercel:: 1987 Wagon 4wd
I read of problem similar to this on a motorcycle forum... It turned out the ignition coil was bad. Thermal expansion and contraction due to temperature caused the erratic behavior.
my bet is on not enough fuel. you've probably changed the fuel filter recently though, otherwise i'd suggest that.
when the engine is stone cold, check the carb fuel level before you start it. if the level is good, then hold the choke open while you look down the barrel and open the throttle by hand a few times to confirm it's squirting as it should.
- Gottolovem
I'm with dlb on lack of fuel what happens If you intentionally try to flood while starting? (Pump the pedal repetitively)
One of my old t4's took a lot of pumping when cold to get it to fire up in the morning.
I'm with dhally- coil problem. Had the same problem years ago with my DD- didn't want to start in the wet after sitting for 10-12 hours. Swapped out the distributor with a used one- problem solved. Then just for the heck of it, I put a near-new coil I had laying around in the original dizzy and re-installed it. Been fine for years now.
Good Luck.
Good Luck.
Another couple of data points: temp was about 34 deg F this morning and it started right up. when it would crank a lot without starting it was about 30 deg. Also, from a stone cold freezing morning, I sprayed starter fluid down the air intake (the flex duct on the end of the air filter assembly intake), and it did not seem to help, though it did start eventually, it was not the instant start I usually expect with ether down the intake.
So I am also thinking coil, or something in the distributor (ignitor, even capacitor). Next step might be to pull a spark plug wire next time it is below freezing and stick on a spark plug to see how well it sparks, and give it a crank.
will also check the float level while I am at it. I also thought of the fuel filter, but usually that will cause stuttering and cut out at high speed/high engine demand (fuel starvation) and rarely affect start up unless fully plugged.
- My tercel:: 1988 SR5 Wagon
hey Petros I'm in the same boat with my 81 tercel.
My car did have a low float level, but correcting this did not help cold starts in this weather.
One thing I find odd since my 81 has a block heater; if plugged in overnight, it will start up easily when being used..
The car was running 10w30, so changed it out to 5w30, but alas no help starting.
Keep us posted when you find out what it is!
2JZGTE-powered Tercel SR5
- Mark
I have an '81 as well. Does yours still have the original points type distributor? It's a 6-volt system instead of the electronic distributor's 12v. I wonder if the spark isn't strong enough in cold weather if the gaps are slightly too large.
