Headlight Relay Harness Upgrade
helipilot77
My tercel:: 1984 SR5 wagon
Re: Headlight Relay Harness Upgrade
Post by helipilot77 »
So maybe not the best example. I'll try to get a better photo.
. / TOYOTA
./_| |/|/ |]
teranfirbt
Post by teranfirbt »
That's pretty good, the rectangular hot spots in the centers are super weird, but could probably just consider that the high part of a standard beam.
Hey all,
I’m finally getting around to wiring the new headlamps, this diagram appears pretty straight forward. Any suggestions (besides ebay) for the relays?
TIA,
CHRIS
https://www.ebay.com/itm/Bosch-03320141 ... SwBLlVCZ3F
These appear to be Bosch, but have a metal case vs plastic. Do you expect they’re ok?
splatterdog
Post by splatterdog »
I would suggest weatherproof automotive relays for under the hood. I use these, the matching relay is shown too.
https://www.waytekwire.com/item/75610/M ... or-75610-/
I also get my wire there, way better than what's found in most stores.
Thanks splatterdog,
It’s been cold enough here in NW Missouri, I’ve seen some tents on the ponds:).
splatterdog wrote: Fri Feb 12, 2021 5:17 pm I would suggest weatherproof automotive relays for under the hood. I use these, the matching relay is shown too.
splatterdog,
The original part # and the one you shared are both 5-pin. Based on the diagram and my understanding, a 4-pin relay would work. Do you suggest not using the 87a pin/wire and just covering it?
splatterdog
The wire for the normally closed terminal can be clipped and capped. I use glue lined shrink tube with a tail that can be pinched shut while still hot.
