KEEP your tranny alive! (what you should do)
another reminder to check the trans/diff oil level
in last 8 months i have collected 4 MELTED transmissions due to running with very low oil level
the seal/seals may only leak a little bit, but a little bit over a long time equals low oil
also if your tranny gets noisy in all 5 gears, its one of the two large bearings in the front of the tranny getting ready to fall apart
stop driving the car and get the tranny out before the bearing totally fails and wipes out the main drive gears
cost of new bearing is less than 50.00 and you can replace it yourself using youtube videos
if tranny is noisy while idleing in neutral but noise goes away when you push in clutch thats the inner Input shaft bearing
it needs to be replaced.
how to check tranny oil level
raise car enough to get under it (raise entire car so its level)
remove plug (24mm/15/16") tha 's located just aft of driver side CV axle (where it enters transaxle/tranny housing)
if oils runs out put plug back in, your OK
if no oil comes out insert a bent piece of wire into hole (try not to touch any thing inside tranny or you will get false reading)
when you pull wire out try to determine how far down the oil level is (kinda like a dipstick)
add oil until it overflows, let it rest for a while and add more till its filled up.
wipe down tranny around axles and rear drive line and 4wd shift lever (thats where the seals are)
drive car for a week and check for fresh oil leaks
seal part numbers
1.4wd lever seal part # "16x24x6" Timken (i ordered from Grainger)
2.rear driveline seal Orig equip # AH1904F
Beck/Arnley #052-3899 (all rubber) SKF #12745 steel shell (12560 is 10mm thk)
3.front axle seals Beck/Arnley #052-3521 National/Timkin # 223240, SKF #12754, (toyota 9031132006)
Re: KEEP your tranny alive! (what you should do)
I have bookmarked this subject.. Great work Xirdneh. Imagine how many Tercels would be kept alive and not gone to the crusher with this information!
splatterdog
Post by splatterdog »
Mattel wrote:I have bookmarked this subject.. Great work Xirdneh. Imagine how many Tercels would be kept alive and not gone to the crusher with this information!
Not just tercels! Every car line has suffered at the hands of their owners...
I don't think I have mentioned it yet this year- Synthetic gear oil!!!!!!!
Post by irowiki »
I thought full synthetic in these transmissions made the seals leak? So a 50/50 mix worked better?
irowiki wrote:I thought full synthetic in these transmissions made the seals leak? So a 50/50 mix worked better?
if you already have leaks or marginal seals, synthetic will exacerbate them but if the seals are good, they will not leak.
Elika
My tercel:: 1985 SR5
Post by Elika »
My transmission went out and I'm waiting to find out if it's repairable, the wait is killing me. I heard a rumor that there are other toyota transmissions that will bolt onto the 4x4 motor with little effort, is there any truth to this?
For 83-88 4wd there are no other tranny's that will work
As far as I know
What was your tranny doing or not doing?
