Adjustable inner CV axle seal installer
Look around here for some great advice on getting the most out of your tools! Tips and tricks!
For installing seal in differential housing where CV axle goes
the FSM says to install to a depth of around .3" (i cannot remember the exact distance and i do not have the book handy)
if seal has been leaking and you are re-using the CV axle sometimes I change the depth that i set the seal so it rubs in a smoother part of the axle
with this installer you can adjust the depth by twisting the threaded part
i used a steel pipe for the threaded part but a black ABS part would work fine
pictures are in reverse order so start at bottom and go up
Re: Adjustable inner CV axle seal installer
that's brilliant, rob
Rob - OK to move to Tool Forum, but leave a shadow in Repair Guides?
If you leave a shadow, the shadows don't stay forever.
95 Camry Wagon, 170k
97 4runner, 275k
irowiki wrote:If you leave a shadow, the shadows don't stay forever.
what are you talking about? is that zen-speak or technical computer-speak?
ARCHINSTL wrote:Rob - OK to move to Tool Forum, but leave a shadow in Repair Guides?
forum mod speak!
97 4runner, 275k
